J-56 in 1966 - NCRS Discussion Boards
J-56 in 1966
  • Howard Nardick
    J-56 in 1966
    Would a 1966 J-56 brake optioned car have the Kelsey-Hayes adjustable proportioning valve?? and would the twin plastic cap power master have two bleed screws and a "PG" stamp?? finally was the J-56 option available on a `66 390hp car??
    ...Thanks in advance!! ..HN
  • Geoff C.
    • May 31, 1979
    • 1613
    no bleeder screws on 65-66 plastic capped mc *NM*
      • 43203
      Re: J-56 in 1966
      HN-----
      Yes, a 1966 Corvette with J-56 would have had the Kelsey-Hayes proprotioning valve. There were no bleeders as Geoffrey mentioned on the master cylinder. There was no "PG" (or any other broadcast code) stamped on the master cylinder. For 1966, J-56 was available only with the L-72 engine.
      • Bill Stephenson
        Re: J-56 in 1966
        Joe,
        -------While certainly not conclusive, I had a 390hp air-conditioned coupe years ago that appeared to have been ordered with J56. The calipers were missing but all the other pieces ,big and small, were on the car and appeared to have never been fussed with. The car had no paperwork and efforts to track it back were unsuccessful........Bill S
        • Wayne M.
          • March 1, 1980
          • 6414
          Here's the proof J56 avail w/all 427's in '66
          And I have GM Canada Records proof that 390hp '67's were delivered w/J56.
          This is from a Vette Vues mag back a while.
            • 43203
            Re: Here's the proof J56 avail w/all 427's in '66
            Wayne-----
            In that case, there is a conflict between the information provided in the 1966 Dealer Order Guide (copy attached) and what was on the Corvette order form. Of course, these things could change during the year. But, this copy of the Order Guide is dated just about the same as the date on the order (of course, the form could have been older than that, but not by too much).
              • 43203
              Addendum
              Wayne------
              From what I can see of the form revision date on the order form (top left corner) it appears that the date is 8/65. So, it may be that between then and the Novemeber, 1965 date of the Order Guide, a change was made regarding the pre-requisite for the J-56 brake system. It might be that the order form was also revised in November.
              • Philip C.
                • December 1, 1984
                • 1117
                Re: Addendum 390s got em
                My friend has an orig 66 with 390 A/C J-56 Been trying to buy it for years its an April car Phil 8063
