63 cig. lighter - NCRS Discussion Boards
63 cig. lighter
  • jim cear
    63 cig. lighter
    Does anyone know what the fix is to prevent the lighter from poping out of the receptical when it finishes heating?
  • Frank C.
    • January 1, 1986
    • 277
    Re: 63 cig. lighter
    My guess would be you need to replace the female socket which you should have no trouble locating
    • Mike M.
      • May 31, 1974
      • 8385
      Re: 63 cig. lighter
      there are a couple(2 or 3) "fingers" inside the female socket of the lighter. remove the socket, bend the finger towards the center of the socket and see if that cures the problem. nothing worse than pushin in the lighter and have it sail back into your crotch , unexpectedly, half way thru the 1/4 mile.mike
      • Dale S.
        • November 12, 2007
        • 1224
        Re: 63 cig. lighter
        Mike , You nor your crotch should smoke going down the 1/4 mile. dale
        • Peter L.
          • May 31, 1983
          • 1930
          Re: 63 cig. lighter
          Jim - Sounds like you have the BIG BLOCK version of the lighter. As Mike indicated, the receptacle will have 2 or 3 fingers (if it's the original style, it will have 3) also the lighter element should be a 63 CASCO. The metal of the fingers tends to fatigue after years of use. Bending them in might work for a while but if the fingers are burned or brittle your best bet will be to replace the receptacle. Also, if the lighter and receptacle aren't the original pieces or if it's some other combination, it will probably be a challenge to get it to work "right." Good luck. Pete
          • Tracy C.
            • July 31, 2003
            • 2739
            especially with all the methane in that area. *NM*
