Back on the carbeurator kick - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    I'm wondering what size m.My Rochester Carb. # 7028212 DH is? 600cfm? 650cfm?
    Plus I was given a Rochester carb 17080213 2909CPX What the H_ll size is this one and what would it fit? I'm thinking truck
    Thanks, Chuck
    Re: Back on the carbeurator kick
    Chuck -
    I believe most Q-Jets are capable of flowing 700-800CFM; I'm sure experts will chime in on the numbers.
    • Myron Sleeva
      Back on the Carburetor kick
      Some interesting reading on http://www.oldengine.org/unfaq/leadfoot/qjet1
      • Harold# 43147
        Chuck all Qjets will flow 750 CFM some Pont.& Buicks HP 800CFM they just increase the Primary Bore 1/32.The top Secondary Air valves will only allow the the amount of air the engine can draw.Thats what made this Carb so universal just by changing jetting & metering rods your carb could be used on 327-454.Chevy never used 800 CFM version 7040205 (1970 454 LS-5 M/T)was the highest fuel-air ratio Qjet for Chevrolet.7040207 is 1970 350/350 HP M/T Corvette only and it is one of the rarest carbs because of it's low year production. I restore Qjets Chevy only 67-74 and have only found 2 of these in the last 5 yrs.
        Just some Data
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Thanks one and all
          Thanks for the insights. I at least now know what I have, and what I'll be up against in trying to carb up the power plant I'm rebuilding.
          Thanks again,
          Chuck
