'63 spark plug wires - NCRS Discussion Boards
  • Mike McKown
    I'm not having any luck finding a set of wires for my '63 fuelie engine. I'm looking for wires with 90 degree boots/terminals on both end and the coil.
    I don't want dated wires, just stock application, good quality black wires with the right terminals.
    Any ideas?
  • Mike M.
    • May 31, 1974
    • 8386
    Re: '63 spark plug wires
    if you want a permanent set of wires, order the lectric limited repo wire set and a coil of delco packard 440 wire and use the boots and terminals off the repos along with the 440 to make up a set of plug wires. they'll allow the engine to perform way better and they'll outlive the repos by decades. mike
    • Mike McKown
      I want a set already made up. Surely somebody makes a quality set with 90/90 terminals?
      • Tracy C.
        • July 31, 2003
        • 2739
        I'm sure #14 could fix you up a set for $500 *NM*
        • Mike McKown
          At the rate I'm going, that might be a bargain
          I've given up on finding a made up set. I've found many brands with 90 degree plug ends but not coil/distributor ends. I purchased some Belden ends that were supposed to work for 90's at the distributor but I can't get a good crimp on them and they pull of too easily.
          What are others doing for wires that have a '63-'65 fuelie?
