Seat Tracks - NCRS Discussion Boards
Seat Tracks
  • Roger S.
    • May 31, 2003
    • 262
    Seat Tracks
    Are the seat tracks for a 70 - 74 Corvette the same? I am looking for a replacement track for my 73 Corvette and am wondering what to get.
    Roger
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Seat Tracks
    Should be the same. I think there was achange in 75 to accomodate the cat converter.
    • William O.
      • April 30, 2001
      • 355
      Re: Seat Tracks
      Try Ecklers, Riks or Corvette America.
      • John O.
        • May 31, 1998
        • 480
        Re: Seat Tracks
        Hi Roger
        Go to 60scorvetteseats.com They have seat tracks and should be able to help you out. I just bought them for my 62 corvette.
        John
          • 43229
          Re: Seat Tracks
          Roger----
          No, 1970-74 seat tracks are not all the same. The 1968-71 are the same. 72-74 are the same but different than 68-71. I don't think that they are a lot different, but I can't tell you exactly what the differences are.
          • Brandon Metzger
            Re: Seat Tracks
            Roger,
            Compare prices then look on Ebay. I have seen some of these go for fairly cheep prices. Even pretty rough tracks will clean up well. Mine were rusted solid. I got them sand blasted by someone localy. They have a commercial set up, a bit more powerful than your typical home set up. When I got them back the tracks looked great and moved very nicely. I then sprayed them with dionizer rust stopper, can find this at Murrays, and then painted them. The tracks now look almost like new and work great.
            Brandon
            • Edward M.
              • November 1, 1985
              • 1922
              Re: Seat Tracks
              The difference is the orientation of the rear mounting bracket that is riveted to the seat track. The 68-71 seat track has the bracket (which is shaped sort of like a triangle with the top point cut off) pointed toward the rear. The 72-74 seat track has the rear bracket pointed toward the front. This changes the location of the rear mounting holes that attach the seat track to the body.
              I don't know if they will interchange, and my dates may be off somewhat.
              Roger, what exactly do you need, I may be able to help.
                • 43229
                Re: Seat Tracks
                Ed------
                Thanks for confirming that. That's exactly what I thought the difference was, but I was not sure enough to say so. I thought that the basic tracks were the same but the rivetted-on mounting brackets were different.
