Need 7040207 quadrajet for a 1970 - NCRS Discussion Boards
  • Mark #44888
    I need a # 7040207 quadrajet. Any good sources out there? Thanks - Mark
  • Dick W.
    • 10483
    Re: Need 7040207 quadrajet for a 1970
    Normally requests for parts such as this are made in the Driveline. You reach 16,000 members. With a large group such as this focused on one make, it should produce results. There are also vendors that advertise in the Driveline that sometimes have these carbs.
    Last resort would be purchase one off Ebabes. You will usually pay premium prices and do not have a chance to view the item prior to purchase, usually with no recourse if it is not what you do want. Buying from a vendor usually have the option to return for a refund.
    Caveat Emptor. There are several individuals that are restamping the carbs. Some do a quality job, most do not. The better ones will "wet test" the carbs to verify function.
    Dick Whittington
    • Mark #44888
      Dick - thanks for the advice. I will check my Driveline, as I forgot about it! I will stay away from Ebay on this one too. Mark
      • Joel T.
        • April 30, 2005
        • 765
        Check with Custom Rebuilt Carbs in NJ, the guys name is Phil. Phone # is 732-356-4333. Some folks on this forum like his work, others are so-so. Personally I have bought cars for my '63 and '61 (2x4 originals) and have been satisfied both times. He evidently specializes in "correct" stuff....
        www.customrebuiltcarbs.com
        • Mark #44888
          Thank you Joe. I'll give him a call. Mark
