Hi,
I was wondering if someone could answer a question about my '60 fuel sender unit. I was having gas leak from around the sender I think because it was not tightened down enough to the tank.
I noticied the fuel unit hold down screws have a rubber gasket around them I suppose to ensure a seal. There are 2 electrical wires running to the sender unit: 1 goes to a post coming out of the top of the sender and the other goes underneath one of the 5 hold down screws. My question is: Is the wire going to hold down screw supposed to be electrically isolated somehow or should it touch the metal. The screw itself goes into the tank so I do not know how it can be isolated.
When I tightened down the screws I have the wire touching the metal plate and the gasket seems to seal now. However, when I now turn on the turn signal the gas gauge moves slightly in sync with the turn blinker. Is this indicative with some grounding problem with the tank or should the wire be isolated. I am a little worried here I my be doing something dangerous because of the gas.
Thank you,
Scott Scearce
Thank you,
Scott Scearce
