Chrome BB Valve Covers - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    I have a set of chromed BB valve covers that came on my '66 El Camino - right angle bend in the middle of the cover to grip 2 plug wires going to the front and vertical "stacks" at the rear to carry a clip for all four wires. All that I come in contact with says that these are correct.
    I also have a pair of chromed covers that are idnetical but WITHOUT the vertical "stacks" at the rear - what is the application for these?
  • William O.
    • April 30, 2001
    • 355
    Re: Chrome BB Valve Covers
    can you post both pictures so they can be identified.
    • William O.
      • April 30, 2001
      • 355
      Question:
      What is the appearance of the VC on the underside of both?
      • Geoff C.
        • May 31, 1979
        • 1613
        My guess would be 66 el camino *NM*
        • William O.
          • April 30, 2001
          • 355
          Re: My guess would be 66 el camino
          Let's see.....maybe this would include:
          Camaro, Nova,Impala and maybe a truck or too.
          • William O.
            • April 30, 2001
            • 355
            ....Not too many CHROME valve covers before 68' unless you had L89/
            • Geoff C.
              • May 31, 1979
              • 1613
              your may be forgetting the le mans el camino
              • William O.
                • April 30, 2001
                • 355
                LeMans was Pontiac... Maybe the Biscayne....
                  • 43221
                  Loren-----
                  There were a "jillion" different configurations for big block valve covers over the 65-75 period of their use in cars. Many of the configuration differences involve only small differences in attached bracketry.
                  As far as chrome covers go, very few were used during the 1965 model year. Z-16 Chevelle MAY be an exception. For 1966 they were used on Chevelles/El Caminos with L-34 and L-78 engines. I believe they were also used on passenger cars with L-72 and/or SS package.
                  1967 continued about the same as 1966. However, the chrome covers were, of course, also used on those few 1967 Corvettes built with L-89.
                  For 1968-70, the use of chrome big block valve covers "exploded". All Corvettes and most other applications except some base big block engines used them.
                  After 1970, the use of chrome big block valve covers was VERY limited.
                  As far as the wire stands go, as far as I know, all passenger car, Corvette, and Chevelle/El Camino used the rear stands. All of these were identical or very similar in configuration and location of attachment. Camaros used them, too. However, for Camaros the attachment point of the rear wire stands was about an inch forward of the location for other applications.
                  Considering that the wire stands were used for passenger cars, Chevelles/El Camino, Corvettes, and Camaros, that doesn't leave much for units without the wire stands. I don't recall if any Mark IV's were ever installed in Chevy II, so that might be a possibility if they were.
                  Of course, there are always light truck applications to consider. However, I don't think that any of those used chrome covers.
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    Both sets have drippers.
