1963 Vinyl Dash Skin - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I will be re-skinning the center fiberglass dash unit using an Al Knoch dash cover. Has anyone ever preformed this task, and are there any helpful tips that you can provide?
    Thanks Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 1963 Vinyl Dash Skin
    You might want to make sure that the vinyl is warm, so it will be flexible. Dry fit first. Only apply the adheasive to the small area you are working on. I did the center section first, around the speaker grill. The most difficult area is at the bottom below the radio. There are a lot of tight turns and bends. Having an assistant for an extra set of hands is a good idea.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks Bob
      Ray
      Ray Carney
      • Ray C.
        • June 30, 2001
        • 1132
        Hi! Bob
        I have all the clips and metal parts off the fiberglass dash panel and I am ready to remove the original skin. Is there any helpful hints for this process?
        Thanks for any help!
        Ray #36314
        Ray Carney
        • Bob R.
          • June 30, 2002
          • 1595
          Someone else stripped mine for me. But I would think using some acetone to loosen the adheasive a little heat to soften things up and patience. Get plenty of ventilation if you are using acetone.
