Intake question - NCRS Discussion Boards
Intake question
  • Markus 38206
    Intake question
    Would it theoreticaly be possible to mount an oval port intake manifold on a big block engine with large square port heads? I know this is not optimal at all, but would it be possible?
  • Warren F.
    • December 1, 1987
    • 1516
    Re: Intake question
    Markus;
    Yes it is, however the opposite would be difficult.
    • Michael H.
      • January 29, 2008
      • 7477
      Re: Intake question
      Markus,
      It's possible to use a large square port intake manifold with oval port heads but I don't think you can use the oval port intake with large square port heads.
      • Clem Z.
        • January 1, 2006
        • 9427
        correct ,michael
        not very effecent but it will fit.
        • Steve Antonucci
          Re: Intake question
          Warren,
          I once looked at a 68 SS 396 ( 375hp ) Chevelle that was reported to be an
          original SHP car. It did have the correct aluminum rectangular port intake
          and Holley carb. At the time, I did not know that 4-bolt main blocks had the
          different hole configuration above the oil filter boss area, so I made a
          condition of sale the removal of one valve cover. Guess what I found?
          Oval port heads...... Seems it was a low horse 396 after all. It did run,
          but not very well under power. Seller claimed it needed to be tuned-up.
          Oh yes, it did have the "factory" 396 - 375HP air cleaner sticker though.....
          Steve
          • Norris W.
            • December 1, 1982
            • 685
            Re: Intake question
            I've bought big blocks over the years that had em done in both directions.....oval on rec. and rec on oval. It'll work either way.
