Another C2 Dash Paint question - NCRS Discussion Boards
  • Scott Marzahl
    I've read all the archives for the suggestions on paint for center dash black paint and suggestions range from Krylon 1613, John Deere Blitz and SEM Trim Black. I have a gallon of the GM Restoration Black Paint mainly used for underhood, if anyone is familiar with this paint, does it have the correct sheen for the dash?
    Scott
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: Another C2 Dash Paint question
    None of the above.
    Except perhaps the SEM Trim Black. I havent used it.
    The Krylon isn't really Black and the "Blitz" is too flat.
    I'll bet someone else will chime in.
    H. a. N. D.
    • William O.
      • April 30, 2001
      • 355
      Seymour's HI-TECH works well.
      • don 42616
        Does Semoures come in spray or can? Can it be used for touchup or just complete repaint? Who carries it?
        • William O.
          • April 30, 2001
          • 355
          It comes in spray cans.
          www.seymourpaint.com
          • Rick S.
            • January 1, 2003
            • 1203
            I have used Seymour Chevy orange engine paint in spray cans and have been very pleased with its coverage and spray nozzle.
            • don 42616
              William is the Hi Tech "gloss Black" Correct *NM*
              • don 42616
                Or the "flat Black" ? *NM*
                • William O.
                  • April 30, 2001
                  • 355
                  Re: Or the "flat Black" ?
                  It not flat black...semi-gloss.
                  • William O.
                    • April 30, 2001
                    • 355
                    Re: William is the Hi Tech "gloss Black" Correct
                    Semi-gloss.
                    • William O.
                      • April 30, 2001
                      • 355
                      Lone Island Corvette.
                      Bill
                      • Joseph S.
                        National Judging Chairman
                        • March 1, 1985
                        • 871
                        I have and still do use the SEM Trim Black. It is great for Semi Gloss interior and exterior use. It is very thin in the can so apply with light coats. I find it is great for restoring that very black color to vinyl items. It is good for use over metal plastic and fiberglass also.
                        I will easily fisheye if your surface has any silicone or wax on it!!!
                        Try some on a test panel and see how you like it!!
                        Good luck.
