window crank lock clip - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    What is the correct direction for the lock clip installation on the window crank handle. Open or closed end of clip toward handle. Thanks ED
  • Mike M.
    • May 31, 1974
    • 8389
    Re: window crank lock clip
    either way will work but i usually aim the open end toward the handle so as to make for ease of removal with my plier-type clip remover. if you have the push-style clip remover, then aim the clip closed end toward the handle, again to facilitate clip removal. mike
    • Ed P.
      • July 31, 2002
      • 270
      Thankyou that is what I needed. ED
      • Scott Butville
        Most of the interior handles for all GM cars and trucks were made at the GM plant in Trenton, NJ. The slots were broached and clips installed on a rotary table machine. The broach moved towards the shank and the clip was installed from the same direction, thus the open end was towards the shank.
