What year? - NCRS Discussion Boards
What year?
  • Chuck R.
    • April 30, 1999
    • 1434
    What year?
    Casting 3970010
    Pad info:
    C6B 140203 K62 13 TXD
    I know it's a 350 four bolt main truck engine, but what year? I'm guessing 75-77
    Chuck
    Re: What year?
    Chuck -
    '76 pickup built at Baltimore, engine cast/assembled at McKinnon Industries (Canada).
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Excellent!
      I knew I was close but wasn't quite sure.
      Thanks John.
      Chuck
        • 43236
        Re: Excellent!
        Chuck-----
        It's not necessarily a 4 bolt main engine, either. Some folks think that all 3970010 blocks are 4 bolt main configuration. They are NOT. Even those used in trucks (and this one would have been installed in a light truck, anyway) were not necessarily 4 bolt. In fact, in the time frame that this engine was built, the majority of 3970010 blocks were NOT 4 bolt. They can be easily converted to 4 bolt, though, assuming that the block is not now 4 bolt and someone feels that is necessary.
        • Frank C.
          • January 1, 1986
          • 277
          Re: Excellent!
          Hi Joe....can one determine 4 bolt from anything on the outside, or is removing the pan the only way? THX Regards Frank
          • KEN BUTCHER
            Re: What year?
            Hey John where did you get the suffix info? all I can give is this:
            TXD- C-10 truck 1975 = 350cu.in. 2bbl 145hp m/t
            TXD- C-20 truck 1975 = 350cu.in. 4bbl 160hp m/t
            TXD- C-30 truck 1975 = 350cu.in. 4bbl 160hp m/t
            TXD- K-20 truck 1975 = 350cu.in. 4bbl 160hp m/t
            As far as I know the egines were assembled at - F = Flint motor
            V = Flint engine
            T = Tonawanda
            Nothing I could find about Canadian engine assembly plants.
            • Clem Z.
              • January 1, 2006
              • 9427
              every 350 truck engine that had a 4 barrel carb
              i found to be a 4 bolt. i can't every one is but the ones i took apart were
                • 43236
                Re: Excellent!
                Frank-------
                There's no way to determine the main cap configuration without removing the pan on a 3970010 block.
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Re: What year?
                  The C6B 140203 is the VIN derivative that reveals the details of the vehicle the engine was installed in.
                  The 'K' in the K62 13 TXD means the engine was built in the McKinnon plant. I believe 62 13 would be February 13th, 1976.
                  • KEN BUTCHER
                    Re: What year?
                    Hi Mike,
                    According to the info I have the small block was assembled at three plants, as I said before, but that the info I have goes up to 1975. Also the dates are a little strange, usually it starts with engine plant which is a letter followed by four numbers and no year.
                    K6213- K = could be engine plant ( where is this plant )
                    6 = no year was stamped on pad ( only cast into block )
                    2 = if it was february it would be stamped 02
                    13 = would be the day
                    This has me miffed, please enlighten me. Thanks.
                    • Clem Z.
                      • January 1, 2006
                      • 9427
                      Re: What year?
                      i was just at a seminar with al grenning and he showed how many block stamping were screwed up at the factory.
                        Re: What year?
                        Ken -
                        There were four V-8 engine plants:
                        "F" ('55-'66) and "V" ('67-up) = Flint V-8
                        "T" = Tonawanda
                        "K" = McKinnon Industries (Canada) - now St. Catherines Engine Plant
                        "S" = Saginaw Service Engine Plant (very rare, hardly ever see one)
                        All used the same stamp format:
                        Plant Character
                        MMDD (month/day)
                        XX Code Suffix (suffix was three characters from 1970-up)
                        • Chuck R.
                          • April 30, 1999
                          • 1434
                          Re: Just for the record
                          My 1976 0010 block has four bolt mains.
