C2 Radio Slider Bar - NCRS Discussion Boards
C2 Radio Slider Bar
  • Dave K.
    • November 1, 1999
    • 952
    C2 Radio Slider Bar
    The AM/FM selector slider bar fit over the little tab shaft that controls AM or FM selection on my 66 radio is loose and the slider bar almost falls off when sliding the bar up or down to change the radio band. One of the two center tangs is broken off the pot metal slider and only one tang remains. The radio works fine. Any suggestins on how to tighten up this fit? The broken tang doesn't appear to affect the slider bar action when changing between bands.
    Dave Kitch
    33108
  • mike mccagh
    Re: C2 Radio Slider Bar
    you might try a product like JB Weld. i believe i've seen the slider bars available as repo's . good luck, mike
    • Dave K.
      • November 1, 1999
      • 952
      Mike,
      I don't think that you want to use JB weld here -- slider must come off to disassemble radio.
      Dave K.
