'69 435HP Intake Manifold questions - NCRS Discussion Boards
  • Kent K.
    • December 1, 1982
    • 1139
    Finally, we brought my old girl home from 3 years safe keeping. It presently has an aluminum intake manifold #3933163 from the Winters Foundry and a Holley carb 4781 with 2/2 below, front bowl 7047 4781 and rear bowl 7049 4781. First questions are what, if any, were the applications for these items?
    I have the factory installed intake manifold and 3 dueces per the original owner who removed and stored them to install a 4 BBL carb/manifold for racing. The manifold is number 3937797 which, according to the TIM & JG, is for the 400HP car yet it came on this 435HP car. All 3 barbs are dated and numbered correctly for original. Is it possible for SN 726231 to have a 400HP intake originally installed instead of the 435HP intake?
    Any help would be appreciated. I'll probably have many other inquiries.
    Kent #6201
    Kent
    NCM Founder - Member #718
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: '69 435HP Intake Manifold questions
    3933163 LS-6 intake and sold over the counter. 4781 universal 850 double pumper
    • Clem Z.
      • January 1, 2006
      • 9427
      PS
      i do not think the 400 HP manifold,oval ports, will cover the rectanglar intake ports on a 435 HP heads.
        • 43221
        Kent-----
        The GM #3933163 was used on many 68-69 SHP big block applications, but none of these included any Corvette. It was available for years as an over-the-counter SERVICE manifold.
        The GM CASTING #3937797 is the rectangular port manifold originally used for 1968 and early 1969 L-71.
        • Clem Z.
          • January 1, 2006
          • 9427
          does that mean the TIM&JG is in correct ??? *NM*
            • 43221
            Re: does that mean the TIM&JG is in correct ???
            clem-----
            It is incorrect if that's what it says. However, my copy of the latest edition available of the 68-69 manual does have it listed correctly as the L-71 manifold. One correction to my earlier post, though, is that it was used for later 1968 and all 1969 L-71. I "reversed" it. All these numbers and dates are hard to keep straight in my 'noggin.
            • Mark #28455
              163 intake will not fit under BB hood
              the 163 intake will not fit under the stock BB hood. Does your car currently have the L88 hood? If so, the air chamber will likely hit the 3x2 setup when you install it.
              Mark
              • Kent K.
                • December 1, 1982
                • 1139
                Correction and Thanks
                Clem, Joe & Mark ----
                Clem - the TIM & JG is correct, I simply read it wrong. Joe, your noggin is great; thanks for all the research you provide to this board and beyond. Mark, the hood was converted to appear similar to an L-88 hood. I might post a picture later of the aftermarket modification from the engine compartment side. BTW - Dicky (Papa Smurf) located a factory '68-69 BB hood and delivered it on his way to Kissimmee. Seems like we're set for breathing and covering the monster.
                Thanks again. Kent #6201
                Kent
                • Kent K.
                  • December 1, 1982
                  • 1139
                  Modified '69 hood
                  Mark --- This photo is of the hood as modified for the original owner for the 3933163 manifold and 4781 carburetor. The outer skin appears like the L-88 although my knowledge is slim pickings for those cars.
                  Kent #6201
                  Kent
                  • Mark #28455
                    is it press molded? *NM*
                    • Kent K.
                      • December 1, 1982
                      • 1139
                      Re: is it press molded?
                      Sure looks that way. What are your thoughts?
                      Photo of engine as I purchased car except for removal of triangular Elderbrock Ram-Flow air cleaner. None of the reproduction valve covers I've seen have the same configuration with brackets and lack of power steering indentation as these. All bolts observed to date appear to have correct head markings.
                      Kent #6201
                      Kent
                      • Mark #28455
                        Valve covers probably original *NM*
                        • Kent K.
                          • December 1, 1982
                          • 1139
                          Mark - you have email *NM*
                          Kent
                          • Howell Jaynes
                            Going back to the original question. If the car really was a 435 hp car, the 3X2 intake manifold would have rectangular ports to match the rectangular ports on the cylinder heads. If it was a 400 hp car, it would have oval ports to match the oval port cylinder heads. It seems hard to believe that the factory would put an oval port intake manifold on rectangular port heads. Also, didn't the 435 hp engines have aluminum heads?
                            Aside from part numbers, you can distinguish an oval port 3X2 intake manifold from a rectangular port 3X2 manifold just by looking at them even though they are installed on an engine. The rectangular port intake runners are noticeably larger.
                            • Kent K.
                              • December 1, 1982
                              • 1139
                              Howell --- Please refer to my posted correction above. I simply read the TIM & JG incorrectly. This car has the original L71 435HP engine including its manifold and 3 carbs that were placed in secure storage in 1981. They were replaced with the 3933163 manifold and 4781 carb by the original owner for amature racing and autocrossing. As to the heads, L71 435HP engines had cast iron heads. L88 430HP and L89 435HP engines had aluminum heads in 1968 and '69 per the TIM & JG, 3rd edition.
                              Kent #6201
                              Kent
