67 bolt on wheels - NCRS Discussion Boards
67 bolt on wheels
  • Charles A.
    • July 31, 1980
    • 180
    67 bolt on wheels
    I have a new set of Corvette America 67 bolt on wheels. Could someone let me know the proper way to balance them and where the wheel weights go. I just know they are supposed to be "static balanced". Thanks.
  • Richard B.
    • March 1, 1989
    • 99
    Re: 67 bolt on wheels
    there are no set places for the wheel weights. they just go were they are needed
    • Alan Drake
      You can balance them with weights on the outside and inside edges to look original, OH find a source for the correct weights.
      Better still find a very good shop that will balance by placing stick on weights inside the rims (outside tire of course) - no marks on rim, but not original.
        The reproduction wheels won't accept weights on the outside of the rim flange; the section is machined differently than it was on the originals.
        Go to www.GSP9700.com (Hunter Engineering) and use the locator feature to find the nearest shop/dealer to you that has a Hunter GSP9700 balancer and have them balance your tires/wheels; their system also identifies/compensates for static and fully-loaded radial and lateral runout.
        I authored a 4-page article in the March, 2005 issue of "Corvette Enthusiast" magazine that describes the patented/proprietary Hunter process in detail, using my '67 reproduction bolt-ons and new Diamondback radials.
        • Charles A.
          • July 31, 1980
          • 180
          Thanks John. I am using the same tires and wheels you are so I will give it a shot.
