Bolts for Rear Leaf Spring - NCRS Discussion Boards
  • Steven A.
    • July 31, 2002
    • 66
    I'm in the process of replacing a fibreglass rear spring with a steel nine-leaf spring on my 66 small block. The fibreglass spring was one of those VBP "dual mount" jobs which did not use the retaining plate bolted to the bottom of the differential. So I bought a new plate and bolts from Corvette Central to use to mount the new spring. Unfortunately the bolts that were supplied were much too long, especially for the front two holes.
    I know I've seen this question come up in the archieves, but I was wondering if anyone knows the correct length for these bolts (mine are approximately 4 inches)? Also, is there a better source for these bolts or are all these parts suppliers selling the same poorly fitting parts?? P.S. I won't even get into the topic of how incorrect the spring itself is, I just hope it's functional.
    Thanks in advance.
  • Steve Wallach
    Re: Bolts for Rear Leaf Spring
    East Coast Corvettes - call Steve Hack
    513-553-2080 Tell him Steve from Chula Vista told you
    to call him, he'll fix you up!
    Good Luck,
    Steve
    • Gary B.
      • February 1, 1997
      • 7033
      CC repro Rear Leaf Spring
      Steven,
      Did you get the repro spring from Corvette Central as well? If so, let us know how it works out. I've been recommending the repro from Eaton Detroit Spring as people report good luck with that spring in terms of ride height. I'm interested in knowing if the CC spring also results in the correct ride height.
      Gary
      • William V.
        • December 1, 1988
        • 399
        Re: CC repro Rear Leaf Spring
        Steven
        There are two bolt sizes available for (63-79)
        For the HD 7 leaf spring, the bolt is 9/16-12x (3-5/16) long.
        For the standard 9 leaf spring, the bolt is 9/16-12x (3-9/16) long.
        BV
        • Steven A.
          • July 31, 2002
          • 66
          Will do. The spring is made by Triangle Spring which looks like a reputable outfit (based on looking at their website). I always thought the top two leaves on these springs were supposed to have no arch to them. This is clearly how CC depicts it in their catalog and web site. The spring I got has all leaves arched. I'm sure it differs from the original in many less obvious ways also. My car is not flight judging material anyway, so I'm not too worried about this, but I do hope the ride height and feel are within tolerable limits. I just wish the suppliers would be up front about what they're selling. Caveat emptor certainly rules.
          • Gary B.
            • February 1, 1997
            • 7033
            Steven,
            The original 9-leaf spring for '66 was a two-stage spring, with the top 3 leaves straight. Triange Spring is a long-time spring manufacture. So is Eaton Detroit Spring. Eaton can supply the two-stage version. I don't know if Triangle offers that version.
            Gary
            • Alan Drake
              Steve,
              If you do not care about the spring for judging then consider the fiber glass style replacement spring. Weight is less and can get the variable spring rate that makes you happy.
              If concerned with look, then get right one now - just spend money once.
              Just a comment not being critical.
              • Roy B.
                • February 1, 1975
                • 7044
                Corvette stop in northern Ca. is great and honest I got mine there!
                  • 43240
                  Steve------
                  All 1963-77 Corvettes originally used spring retainer bolt GM #3833486. This bolt was a 9/16-12 bolt of 3-7/32" long. It was a special GM 280M (SAE Grade 5)bolt in that it had a non-standard shank-to-thread length. Since the shank of the bolt "aligns and locates" the spring, in this configuration, a minimum of threads were in contact with the spring.
                  The GM #3833486 bolt was GM -discontinued many years ago and replaced by GM #9428598. This bolt is a GM 300M bolt (SAE Grade8) more-or-less standard shank-to-thread configuration. It has a total length of 3-3/4" and a thread length of 1-3/8". Unfortunately, it's been discontinued, too.
                  I don't understand how a bolt that is about 1/2" longer than the original was used as a replacement, especially in this situation in which bolt length is somewhat critical. However, I can tell you that either of these bolts will work just fine with a spring of ORIGINAL THICKNESS.
                    • 43240
                    Addendum
                    Just so there is no confusion since I used the term "bolt" instead of "bolts", I AM talking about the spring retainer bolts of which 4 are used per car. I am NOT refering to the spring CENTER bolt which is a 5/16", special head bolt.
                    • John L.
                      • September 30, 1996
                      • 159
                      Steve & Joe, When I changed out my spring on my 79 I installed new Grade 8 Bolts of the correct lenght (as per what Joe mentions) I have had no problems with them so far. I got these from a local bolt jobber, I'm sure I paid less than $10.00 for all 4. Since Joe mentions that original GM bolts were grade 5, I feel comfortable with my choice. John
                      • Steven A.
                        • July 31, 2002
                        • 66
                        Steve: Thanks. I spoke with Steve Hack today and I think he has what I need.
