'68 horn not working - NCRS Discussion Boards
  • Bryon P.
    • April 1, 2005
    • 5
    My horn does'nt work on my '68. It just clicks when I press the button. Can anyone give me instructions on how to trouble shoot it? Step by step. Thanks, I promise I won't use it indiscriminately.
  • Dick W.
    • 10483
    Re: '68 horn not working
    Assuming the click is the horn relay working, I would go to the horn and see if in fact that you have power when you depress the horn button. If not go back to the horn relay (located inside the left inner fender) and see if you have power out to the horn. If not, and the relay has power going to it, I would have to assume that the relay is bad. Vendors such as John Pirkle have restored relays available.
    If you do have power to the horn, then I would remove the horn and clean the mounting area, thereby assuring a good ground. That failing, if I wanted to keep the original horns, I would consider sending them out for repair. There are two people that I am aware of that provide that service, Dennis Portka and Ron Goralski. You should be able to find their contact information in the Driveline.
    Good luck
    Dick
    Dick Whittington
    • Bryon P.
      • April 1, 2005
      • 5
      Thank you very much Dick. This will really help me.
      Bryon
