Holley - NCRS Discussion Boards
Holley
  • Dale S.
    • November 12, 2007
    • 1224
    Holley
    I found a Holley Metering block in my parts stuff. It has 2544 stamped in the top. Cast inside is 34R-1535B. In the same location on the opposite side is 50. Anyone know what this is from? Also 2 plates with the numbers 34R-2007B above that a 2 and above that is 14. and R34-5113B with a 1 above that and -4 above that. The -4 has a paper gasket on it and the -14 has a metal plate the size of the gasket. Thank you Dale
    • 43221
    Re: Holley
    Dale-----
    I can't find any Chevrolet application for the 2544 block. There may be one, but I can't find it.
    • Dale S.
      • November 12, 2007
      • 1224
      Re: Holley
      Thank you Joe. Dale
