C1 Engine Compartment Paint or Finish - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    I did look at the JG, but I'm not sure I'm reading it right. Can anyone give me the paint or finish colors for the following engine compartment items on a 1962 340HP.
    fan blades
    fan clutch
    fan/water pump pulley
    water pump
    engine mount
  • Rob Edwards
    Re: C1 Engine Compartment Paint or Finish
    Chris- this is what I think is correct:
    fan blades: semi-gloss black
    fan clutch: natural/unpainted
    fan/water pump pulley: semi-gloss black
    water pump: chevy orange
    engine mount: uprights: semi-gloss black, crosspiece: chevy orange
    Hopefully Mr. Ernst will be along shortly to grade my work......
    • Chris H.
      • April 30, 1990
      • 817
      Heres what I did and you pass by my standards.
      gloss black: dipstick, Radiator, coil, heater air hose brackets, coil springs, Horns
      semi-gloss/med gloss: vent tube, vent tube bracket, crankshaft pulley, fan pulley, fan, oil canister. Spark plug wire routing supports, radiator shrouds, washer vacuum canister, third arm bracket, Heater hose clips, stab bars, bushing brackets, steering column mast, clutch linkage, bumper brackets, frame, front crossmember, front control arms, brake drums, backing plates, tie rod sleeves, frame
      Natural: clutch rod thru firewall, Tie Rod Ends, Pitman Arm, Spindle, Spindle supports, steering box, third arm, dipstick tube, Drag Link and Rear spring bands & liners all unpainted.fuel, brake lines, The rear springs may or may not be painted black and the top leaf silver.
      • Mike E.
        • February 28, 1975
        • 5139
        Rob--
        Move to the head of the class!!!
