'67 Master Cylinder Cover - NCRS Discussion Boards
  • Jean C.
    • June 30, 2003
    • 688
    In what order do the instructions on a correct cover read? I'm looking at a cover that does have the correct wording on the two areas; however, the owner thinks the cover is incorrect. TIM&JG was inconclusive.
    When viewing the cover with long dimension left to right, the left buldge has "Service" and "With" appearing in the NW and NE quadrants respectively. "Delco" and "Parts" appear in the SW and SE quadrants respectively. All lettering is oriented "right side up". Owner thinks lettering should be continuous around the circle, e.g. "Service" & "With" as above but with "Delco" in SE quadrant and upside down, "Parts" in SW quadrant upside down as viewed.
    Comments?
    Thanks and best regards,
    Charlie
  • William O.
    • April 30, 2001
    • 355
    Re: '67 Master Cylinder Cover
    Mine appears to be like yours, even the 69' and up with the SAE wording are similar.
      • 43203
      Charlie------
      The owner is incorrect. The script is just as you described and is all "right side up" as viewed looking over the driver's side fender of the car.
      • Jean C.
        • June 30, 2003
        • 688
        Thanks gents. *NM*
        • Joe R.
          • March 1, 2002
          • 1356
          Hi Charlie:
          Here is a photo of an original 67 cap. Not all the words are visible in the photo, but I think that enough is readable to answer your question.
          • Jean C.
            • June 30, 2003
            • 688
            Thanks Joe-- '67 Master Cyl Cover *NM*
