A.O. Smith& St louis - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    Is there a way to tell an A.O. Smith car from a St.Louis car by the window sticker or if not, by some other means?( coding on the car etc.) thank you
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12738
    Re: A.O. Smith& St louis
    From the trim plate you should be able to tell them apart. All is perfectly described in the Restoration Guide on C2's of Noland Adams.
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
    • Dale S.
      • November 12, 2007
      • 1224
      Thanks Rob, I'll up date my cars in the registry. D/
        Dale -
        The most obvious clue is on the trim tag. If the body number is prefixed with an "A", it's an A.O. Smith body ("S" was prefixed to that number on St. Louis bodies).
