65 Dash harness ?? - NCRS Discussion Boards
65 Dash harness ??
  • Dick G.
    • May 31, 1988
    • 681
    65 Dash harness ??
    Where do the 2 white plastic push-in pins imbedded into the dash harness snap into behind the gauge cluster. Do they snap into the dash itself underneath the dash pad. Mine were not connected when I took the old harness out of my car. Thanks Dick Gutman
  • Grant M.
    • August 31, 1995
    • 448
    Re: 65 Dash harness ??
    Dick,
    I can specify exactly where, but I believe that they are designed to snap into holes on the back of the cluster itself or the dash cross-member, either place apparently intended to support the weight of the dash harness and prevent strain on connections or cause lights/etc to pull out of socket locations over time from vibration.
    Hope this helps.
    Grant
      Dick -
      Those two plastic retainers snap into two small holes in the back of the cluster can, near the top.
      • Dick G.
        • May 31, 1988
        • 681
        Thanks John: That makes sense. There is no evidence where these clips go in my 65 AM, but I see them in my 67 AM. I guess I will need to look at both from now on. Dick Gutman
