C1 Crankshaft Pulley Question - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    Trying to determine the part number for the crankshaft (drive) pulley for a 1962 300 HP Corvette.
    My Chevrolet parts book (in Group 1.066) lists it as 3849739. But I can't find that part number anywhere. I thought this was a pretty common part - most if not all C1 drive pulleys.
    Paragon lists it as 3756328. They're usually pretty accurate.
  • Michael H.
    • January 29, 2008
    • 7477
    Re: C1 Crankshaft Pulley Question
    Chris,
    The 3756328 would be the correct part number for the crankshaft pulley for your 62. It's listed in group 0.659. The 3849739 is a belt in group 1.066, but it's not the correct original part number for a 62.
      • 43222
      chris-----
      GM #3756328 is the pulley you need. It was used for all 1958-61 Corvette and 1962 with 250 and 300 hp. It was discontinued in June, 1989, but, as you've found, it is available in reproduction.
      • Michael H.
        • January 29, 2008
        • 7477
        Didn't I answer his question properly?
          • 43222
          Michael------
          Yes, you did. I simply added some additional information.
