68 corvette jack question.....? - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    When the 68 corvette came from the factory, did it use some sort of pad between the spring and the jack? Just wondering. Terry
  • Wayne P.
    • August 31, 1975
    • 1025
    No *NM*
    • Steve Wallach
      Re: 68 corvette jack question.....?
      I have a 68, and from what I have found, there was no pad, only the jack handle "grommet".
      Steve
      • Jim B.
        • July 31, 2002
        • 146
        I assume you are talking about the jack used to lift the car to fix a flat. If so, my original jack does not have any spring other than the one that holds it in the well. Mine had no padding of any kind. My jack handle never had any grommet and was all metal. My jack is all metal as well.
        Jim Boudreaux
        LA Chapter, NCRS
        _____________________________
        1968 British Green Convertible 327/350HP Original Owner
        2002 Z06 Black on Black Original Owner
        2007 Z06 Velocity Yellow w/Black/Titainium Original Owner
        • Terry F.
          • 2061
          Thanks for the information....Terry
          • Jim T.
            • March 1, 1993
            • 5351
            My original jack has no pad between the hold down spring and the jack. The lug wrench has rubber around the lug nut end.
