C2 fuel sending unit - NCRS Discussion Boards
  • John G.
    • January 1, 2004
    • 238
    Is the correct part number for a C2 ('64) gas tank sending unit 3001506?. I plugged that number into the GM Parts Direct website and it came back as being available as part number 6428164. Is this correct? I figure to replace the original sending unit in my car and want to make sure I've got the right part number.
    I searched the archives and it appears there were possible issues with the repro sending units. Should only GM sending units be considered?
    John
  • Alan Drake
    Re: C2 fuel sending unit
    64 fuel sending unit is # 6428065 Good for 63 - 67, however I'm not sure if that number has changed. The # 6428164 is for 68 - 72. All information is from 53-72 Parts Catalog. You should be getting some expert response soon with better details, just thought you might want to try this other number first.
    • Donald O.
      • May 31, 1990
      • 1588
      The original part number for your 1964 sending unit was 6425113. This was a carry over from 1963. The part number for the 65, 66, & 67 was 6425827. Now if you had the N03 (big tank), the number was 5642798 for all mid years.
      Don
