'66 small block a.i.r. mix valve# - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I have two valves, both stamped GM, one has 26295 and the other 33597 stamped. Are either of these valves original for a '66 small block? Physically, they appear correct, but I assumed the part# from the assembly manual would be on them.
    • 43222
    Re: '66 small block a.i.r. mix valve#
    Rob------
    I don't think that either valve is correct for a Corvette. However, I don't know what they are correct for. From what I an tell, it's not Chevrolet, although they could be for a truck application.
    The 1966 Corvette small block valve should be stamped "36195".
    • Mark G.
      • March 1, 2001
      • 227
      • Rob A.
        • December 1, 1991
        • 2126
        Mark,
        One of the valves with 26295 appears to have the original bracket that mounts to the air cleaner stud...the # sure is close to the one you posted, what do you think?
        • Rob A.
          • December 1, 1991
          • 2126
          Joe,
          Upon comparing the valves to pictures of originals, I see now that on the ones I have, there is a small diameter outlet for a hose on top, that is not on originals. I see now that they are not physically the same.
