C2 TI Amplifier Replacement - NCRS Discussion Boards
  • Alan Drake
    Putting my 1964 back to stock. Since the 70's have used a MSD when TI Amp failed. Never had a problem with MSD, but need to go back to stock. All wiring and connectors are still in harness and still have TI Amp box. It appears that I can use:
    1. HEI with different wiring. Tried one in the 70's,but unable to make it work. Would try again if somebody has made it work and can send me the wiring diagram.
    2. Purchase old style pc board from TI Specialties. Of couse that's old technology.
    Thanks!
  • Wayne M.
    • March 1, 1980
    • 6414
    Considered the solid state board ?
    Bolts right in to your existing TI box; nobody will know it's there. Get it directly from M & H Industries at www.wiringharness.com.
    • Alan Drake
      Re solid state board, works??
      Have heared on past posting that the after market board has starting problems. As I recall, something about not working until the key is returned to run postion, ie no spark in start position.
      Is M&H this one?
