C-3 side view mirror - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1888
    For any of you needing to tighten up the side view mirror on your C-3 and are hesitant to soak it in lacquer thinner for fear of destroying something, fear not. I just performed the tightening on my '69 mirror (Paragon reproduction with dated mirror) and it worked perfectly. I soaked the head of the mirror over night in a pyrex bowl and the glass fell out without any prodding and absolutely no damage to the glass or chrome. I used a small drift to re-peen the rivets holding the flat steel across the ball of the arm and it tightened up. Will it stay tight? We'll see next summer. Hope this helps.
    Jeff
  • Terry F.
    • September 30, 1992
    • 2061
    Re: C-3 side view mirror
    If you hit the rivets with super glue before you peen, I think it really helps things for the long term. That pot metal can only hack getting hammered about once in a lifetime. I put some more on after it has dried. Just my two cents worth. Terry
