'65 Shock/Strut Mount LH and RH Part Numbers??? - NCRS Discussion Boards
  • Joe R.
    • March 1, 2002
    • 1356
    Re: IMO, the orginal (Non-F40/41) were angled
    Here is the second photo from Wayne Midkoff. This shows a subtle characteristic of the original shock mounts that is not duplicated in some of the reproduction mounts. If you look closely, you can see that the tops of these two mounts angle away from each other.
    The effect is that the centerline of the shaft that goes through the strut rod does not intersect the centerline of the shaft that goes through the shock. The amount of the offset is small.
    • Joe R.
      • March 1, 2002
      • 1356
      Re: '65 Shock/Strut Mount LH and RH Part Numbers??
      Hi Joe:
      Are you sure you didn't mean the other way around when you referred to the one on the top and the one on the bottom in the ebay photo that Rob Axel mentioned? My 3820929 and 3820930 look like the one on the top. So do Wayne Midkiff's, which appear in a photo that I just posted for him.
      • Rob A.
        • December 1, 1991
        • 2126
        #18
        Wayne,
        Looks like you and I were referring to different angles..looking from the top and looking from the side.
          • 43221
          #19
          Joe-----
          Yes, I reversed it (haste makes waste).
          • James W.
            • December 1, 1990
            • 2655
            #20
            Thanks to all of you who posted descriptions and photos. The shock mounts that I am referring to are off of an original, low mileage 1965, 396 c.i. convertible with a standard suspension, the car has never been apart before now. The photos from Wayne are exactly what I have. As I sit here typing this, I'm looking at a pair of reproductions that have no part numbers cast into them at all and have none of the curves as seen in the orginals, but they are marked with a sticker for left and right sides. The owner of the car that I am helping to restore had bought these reproductions because in removing the originals, he had done damage to the threaded ends and thought they were un-repairable. I told him that I was not inclined to put a reproduction part on this car unless all other avenues had been exhausted. I repaired the threads and they are good to go back on the car. I have since banned him from removing anything from the car if it involves the use of a BFH and/or a vice-grips.
            Thanks again to Joe, Mike, Wayne, Jon and anyone else who responded. I got a lot more info than I needed, but I learned something new, and that's always a positive in my book.
            THANKS GUYS!
            James West
            Omaha, NE.
