C1 283 270 hp - NCRS Discussion Boards
C1 283 270 hp
    • 15676
    Re: C/R For 64
    Yes, that's the part number evolution, but without drawings or careful side by side comparison/measurements, we don't know what, if any changes, there were to the geometry that would effect CR.
    • Clem Z.
      • January 1, 2006
      • 9427
      NHRA specs for 340-365 HP 1962-3-4
      they all list the same piston,.122 dome,5.3 ccs. heads 1962 62.2 ccs,1963 59.2 ccs,1964 58.6 ccs
        • 15676
        Re: NHRA specs for 340-365 HP 1962-3-4
        Curious how the chamber volume went down in '63 with no changes and then again in '64 with the chamber radiusing for the 2.02" valve. I think there may have been some "specsmanship" going on to help racers get the highest CR possible.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          Roy, I deduct 500 points for comp gaskets... *NM*
          • Clem Z.
            • January 1, 2006
            • 9427
            the other source i have is i would guess SAE,because it list everything,cam specs,cam#,carb# etc, show the same ccs
              • 15676
              My copy of the '63 Corvette specs list TOTAL combustion chamber volume, but the head chamber volume is not listed.
              • Clem Z.
                • January 1, 2006
                • 9427
                mine lists 62.2 ccs head 4.72 ccs gasket
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Re: Dennis sure you do, tire pressure too *NM*
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    #24
                    Clem,
                    That's interesting. I just learned something. I always assumed 62 and 63 castings were basically the same.
                    • Leon Brown
                      #25
                      Re: C1 283 270 hp
                      Thanks everyone, great info.
                      LEon
