Quartz Clock Point Deduction - NCRS Discussion Boards
  • Rick S.
    • January 1, 2003
    • 1203
    What would the point deduction be for having a quartz clock in a C2 (1967)?
  • don 42616
    25 points. *NM*
    • Gerard F.
      • June 30, 2004
      • 3806
      25 on Operations *NM*
      Jerry Fuccillo
      • George D.
        • August 31, 2000
        • 225
        Re: Quartz Clock Point Deduction
        Why would there be a 25 point ops deduction? Ops only determines whether or not something works. That is like saying you should get a full ops deduct if you have the incorrect headlight, wiper blades, etc. As long as they function you should not get a deduct. If you are doing PV than I would agree with a full deduct.
        • William C.
          • May 31, 1975
          • 6037
          Per the judging guide in the "operations" section, "A quartz type conversion requires a full deduct" It does not "operate" in the correct (original) manner.
          Bill Clupper #618
          • Chas Henderson #28127
            ReWhats the point?
            I guess it makes no sence to change it. I have the original one in my car, and it operates when it feels like it, and when I have had it judged, I have never lost all the points. I lost 13 if it didn't run due to the fact that it can be set and the hands moves. Maybe a over generous judge, but even if was a quarts, I still don't think a full deduct is right. It is working and keeping time. Its could even be original clock with the quartz guts. A half deduct, but not a full. Just my two cents.
            Chasman
            • Kent K.
              • December 1, 1982
              • 1139
              Re: ReWhats the point?
              Chasman --- Runs when it feels like it? That's whay my '67 clock did and it only needed cleaning and lubricating. I used Roger Scott to do the work at a fair reasonable price. His web page is http://www.corvetteinstrumentservice.com
              Good luck, Kent #6201
              Kent
              NCM Founder - Member #718
              • Gerard Q.
                • February 1, 2000
                • 284
                Point deduction I received
                I received a 12 pt deduction for a quartz clock in my 71 at a regional in 2004. The clock line item on the judging sheet states "Clock & reset function". The reset worked, the clock failed so I received half the total deduction. Don't know if it's the same for a 67.
