C1 59 Temp Sender Wire - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    How close to the end of the temp sender wire should the protective coating go and what color is the wire connector? Thanks, Jimmy
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 59 Temp Sender Wire
    Per the wiring print, the loom should start at 2 1/2 inches back from the FRONT end of the connector. Original connector (part number 2962965) is BLACK.
    Bill Clupper #618
