Stripped holes - NCRS Discussion Boards
Stripped holes
  • Terry R.
    • March 1, 2005
    • 359
    Stripped holes
    Any good ways to repair stripped holes in fiberglass where trim screws go in? Thanks Terry #43499
  • Rob A.
    • December 1, 1991
    • 2126
    Re: Stripped holes
    I've had good success using plastic drywall anchors. If you need it perfectly flush, you can trim off the lip after tapping it into place, or use the ones that don't have a lip on the end.
    • Terry R.
      • March 1, 2005
      • 359
      Re: Stripped holes
      Exellent idea!!! Thanks Terry
      • Barry K.
        • March 1, 2004
        • 164
        Re: Stripped holes
        I'll agree with Rob here on the drywall anchors.
        Last month I removed a lot of my interior trim panels to repaint and discovered ALL the screw holes had those blue drywall anchors in them. At first I thought what a "Bubba" thing to do and was going to pull them all out but realized it would be a lot of work to reglass over all the enlarged holes and redrill them plus the fact that the drywall anchors are actually doing an excellent job so I left them in. In fact, in a couple of holes I ended up pulling them and replacing them with new ones.
        Hey, they work great and can't be seen so why not?
        • Mike M.
          • May 31, 1974
          • 8385
          Re: Stripped holes
          i cut a 1 1/2" square piece of 18 guage metal and rivet it to the BACKSIDE of the fiberglass panel with pop rivets. doesn't extend the new door panels away from the door enough to see the plastic drywall plugs. the metal almost always retains its threads for the trim screw. have c-1's that got this repair 30+ years ago and the trim screws still holding super. takes more time to do than the drywall approach but worth it in my opinion. mike
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            Agree w/Mikie, This is...
            ...the very best way to approach the problem.
            • Rob A.
              • December 1, 1991
              • 2126
              Re: Agree w/Mikie, This is...
              If you use the type of plastic anchor that has no lip on it, and you cut off the part of it that sticks out the back of the hole(if it does)the repair will be invisible after the screw is installed
                Corvette Central sells a "Mount Hole Repair Kit" #131125 that has 20 pre-cut/pre-drilled 1-1/4" x 1/2" steel plates and 40 pop-rivets for performing the repair Mike noted above; I went through almost one entire kit when I restored my '57 ten years ago. Pop-rivet them in place on the backside of the panel, drill the screw hole in the plate using the hole in the trim part as a template, drive the screw, and you're in business.
                • Mike E.
                  • February 28, 1975
                  • 5138
                  One more affirmation of the riveted pieces of metal being the best way. I guess, with my profession, I should say "Amen" to that.
                  • mike mccagh
                    Amen inappropriate. "Pass the collection plate" works for me. mikie
