Undercoating - NCRS Discussion Boards
Undercoating
  • Jeremy Hedges
    Undercoating
    What is the best undercoating for a C2? The factory undercoating seems to be pretty thick. What have you'll had the best luck with?
    Jeremy Hedges
    #31711
  • William O.
    • April 30, 2001
    • 355
    Re: Undercoating
    Question:
    Undercoating in what area? wheelwells?
    Bil
    • William O.
      • April 30, 2001
      • 355
      Re: Undercoating
      The undercoating from Long Island which is used on the tops of the inner fender wells works well, if you want a general undercoating you cam use 3M's professional rubberized undercoating.
      • Roy B.
        • February 1, 1975
        • 7044
        Re: Undercoating
        Before you undercoat the front fenders if your ever going to use the Corvette and not trailer it ,I sajust you add a sheet of 1/8 rubber, glued on first. That will protect star cracks from rocks hitting the under fender area.
        I did this to my 55 and have driven 100,000 miles with none appearing yet.
        • Steve D.
          • February 1, 2002
          • 990
          Re: Undercoating
          Roy
          How much of the underside did you cover with rubber?
          Steve
          • Roy B.
            • February 1, 1975
            • 7044
            Re: Undercoating
            Mainly from the headlight to the rear splash panel and 12in wide . Any one going to use ,drive their Corvette should add it before under coating which will help hide what you did. I cant see losing any points worth worrying about even if you have it judged. But I tell you it works and stops the worry of stars appearing in your big dollar paint job.
            • Steve D.
              • February 1, 2002
              • 990
              Re: Undercoating
              Roy
              Not trying to be a pest, but where did you find the thin rubber sheeting?
              Steve
              • Christopher R.
                • March 31, 1975
                • 1599
                Re: Undercoating
                Would a cut up inner tube work? Seems too thin.
                I too have no idea of where to find 1/8" rubber sheeting.
                • Richard B.
                  • March 1, 1989
                  • 99
                  Re: Undercoating
                  the factory never Undercoated any car. the dealer did it as there dealer prep
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Re: Undercoating
                    I just had a 1/8 sheet, but you could use the old inner tube ,just double it up or to what you feel is OK.
                    Factory undercoating no, dealer did, so much for as it came from the factory, was a dealer prep.
                    Imagine each dealer doing the undercoating exactly the same NO!
                    So if you had more or less who can argue with you.But people will.
                    • Brandon Metzger
                      Re: Undercoating
                      Where can you buy the undercoating for the wheelwells? I will need to recoat my front and one rear, perhaps both rear. OH, this would be for a '72.
                      Brandon
                      • Richard B.
                        • March 1, 1989
                        • 99
                        Re: Undercoating
                        any good auto parts stores, or body shop supply stores will have the it. try and get 3M
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          Re: Undercoating
                          You can get it at any parts store in a raddle can "Spray can" goes on good and looks good. 3M
                          • Brandon Metzger
                            Re: Undercoating
                            Thanks guys.
                            • Randy R.
                              • March 1, 1983
                              • 477
                              Re: Undercoating
                              1/8 in rubber sheet can be obtained at a plumbing supply house. They call it rubber gasket material. Be sure to ask about the color. Most of it is red but I think black is available.
