1973 L-82 TCS Temp. Switch - NCRS Discussion Boards
  • Tim Keeler
    Hello all: I'm currently on a business trip and away from my G.M. parts catalogs. Can anyone, especially Joe Lucia, look up the original part number for this TCS temp. switch and send it my way? Thanks in advance, Tim 26883
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 1973 L-82 TCS Temp. Switch
    Going on a business trip and NOT taking all your documentation with you? What were you thinking? ;-)
    My AIM shows the original PN to be 6270698. Hope that helps.
    Mike
    Did you get anywhere with your survey?
    Quebec NCRS Chapter
      • 43221
      Tim----
      I believe that the part number provided by Mike Ward is the TCS RELAY, not the temperature sensor which mounts into the right rear cylinder head and is of brass construction with a right angle-configured, two-bayonnet style connector. For 1973, I believe that the temp sensor for the TCS was GM # 6490453, which is GM-discontinued. However, this part is available from sources like Dr. Rebuild
      • Tim Keeler
        Joe / Mike, Thanks for the number, as always, I appreciate the help. Mike, I ran a mini survey on the board and as you and I discussed, zero input. Oh well... Thanks again guys, Tim
