How Not To Buy Parts--Chapter II - NCRS Discussion Boards
    • 43222
    Well, I've got a few more lessons in how not to buy parts. Herewith----
    eBay #4601049693------This item is a GM #3877660 thermostat housing. It opened at $0.99 without reserve, drew 12 bids, and closed at $93.52. The seller claimed that it was a REAL '660' and had the "raised beveled underside ring". The seller is absolutely correct, too----this is a REAL '660' and will have the "raised beveled underside ring" (although it can't be seen in the picture). The problem is that while it's a REAL '660' thermostat housing, it's NOT THE ONE used in PRODUCTION from 1966 through 1972. The PRODUCTION piece was configured differently at the base. This is a SERVICE-only configuration which came into being about 1990, or so. So, from a restoration perspective, it's worthless; I'm sure that even the most novice judges will spot this from a mile away. From a FUNCTIONAL perspective, it's just fine. But, you don't need to spend $93 for a functional thermostat housing. You can even get a Paragon reproduction which is virtually identical to the original for $40 and you can get an aftermarket replacement (which is just about the same as the one in the eBay item except for the part number on it) for about $10.
    eBay #4600453887-----This item is a set of 16 of GM #3959182 rocker arms for Mark IV big blocks. These are the "H" stamped rockers which were originally used only on 1969 L-88/ZL-1 and 1971 LS-6. These rockers were not originally supplied with rocker balls or nuts, but the seller included a complete set of GM #5232762 rocker balls and GM #3896648 rocker nuts with the rocker arms. The auction opened at $9.99 with no reserve, drew 27 bids and closed at $206.77. Also, based upon my inspection of the parts as can be seen in the pictures, I am quite sure that they are accurately represented. So, what's the problem? Well, you can still purchase the GM #3959182 rocker arms from GM. Now, though, they come in a unit package under GM #12368082 which includes 1 GM #3955182 rocker arm, 1 GM #12338047 rocker ball (same exact configuration as GM #5232762 except made of better material), and 1 GM #3896648 rocker nut. What's more, you can purchase a complete engine set of these under GM #12368085. This set carries a GM list price of $91.36, but can be easily purchased for about $70. So, why pay $206.77 for the same thing?
    As I've said before, don't blame the sellers. They described the items perfectly accurately, they held no reserve, and they started the auctions at a VERY reasonable price under any circumstances.
  • Warren F.
    • December 1, 1987
    • 1516
    Re: How Not To Buy Parts--Chapter II
    Joe,
    I happen to look into possibly bidding on BOTH those items! Man, am I glad you post these lessons. I am going to order the rocker arm kit you talk about.
    Thanks again for the education lessons!!!!!!
    • Gary #41345
      and who made up that term "Buyer Beware" ... and how many fish are there in the ocean? anyone care to guess? Funny thing is hold on to those parts long enough and they will end up being double what the buyer paid for them and he then transforms from fish to shark in a short amount of time.
