67 Dash/ Gauge Wiring - NCRS Discussion Boards
  • Brandon K.
    • April 1, 1997
    • 474
    Anyone happen to have a picture of what the back of a midyear gauge panel looks like prior to being installed? I'm trying to find out where the capacitors and ground tabs are bolted on. Thanks in advance!
    Brandon
  • Alan Drake
    Re: 67 Dash/ Gauge Wiring
    Just been talking about some of these, see C2 Ignition Switch, ground missing below.
    Appears to be two caps.
    1. Cap 1960959 mounted just below the Amp meter using the existing hex screw that holds the gauges in place. Runs parrell to bottom of cluster with wire facing towards center. The wire has a flat copper tab on end which is pushed into the connector of the Amp meter, believe the "Amp Battery terminal" side.
    2. Cap 1960960 mounted below Oil Gaugue, same location but other end now, using the existing hex screw. The wire however faces towards the radio, has a connector on it and plugs into the ... well this has become a question. See my posting below.
    If you could check for another cap on the frame that the radio ground goes to and check for another cap on the existing screw by the Temp Gauge I would appreciate it (don't think you will find).
    3. A ground tab is located above the top of the Tachclose to the Parking Brake Alarm lamp under the existing hex screw.
    The locations can be found in the 63/64/65 Shop Manuals and the AIM's. I do not have a 67 Manual.
    • Floyd #21606
      Brandon, Check your email, I think the picture is what you are looking for.
      Floyd
