C2 Power Window Wiring Routing 1966 - NCRS Discussion Boards
  • Phil B.
    • Today
    Hi - converting a 1966 Coupe to Power Windows. I have the correct wiring harness, but am not sure of exact routing of the wiring. Does it start at the switch cup head towards the back of the car, then doubles back and runs under the carpet towards the dash. Is this correct and if so which side (Passenger). Any pictures or diagrams? Any recommendation where to get rubber grommets forthe fire wall? Thanks.
    Re: C2 Power Window Wiring Routing 1966
    Section A31 in the Assembly Manual shows the harness installation and routing in detail. There are no firewall grommets associated with power windows, but Doc Rebuild has them for all the other applications.
