C2:67 Carpet tag - NCRS Discussion Boards
C2:67 Carpet tag
  • John M.
    • February 1, 1997
    • 52
    Re: John Mulligan - note
    Yes. One of us has the Australian option.
    Original caution label still in place with excessive glue around edges especially to the left.
      Steel cars used the same sticker, complete with sloppy installation and excess glue - here's the same sticker on my original '69 Z/28.
        Director Region V
        • August 31, 1994
        • 1463
        Re: C2:67 Carpet tag
        The top third of those numbers along the bottom edge represents the date (MM/DD/YY).
        With the spacing, the four digits look like day and year. The month to the left appears to be mostly torn off.
        Same orientation for the storage cover tag.
        H. a. N. D.
        • Gerard F.
          • June 30, 2004
          • 3806
          I see what you mean
          Michael,
          The second number (day) appears to be 28, third is 67. My assembly date (22049) I believe is 06/29/67.
          Would you think the carpet would be that close to the assembly date or a month or two before? I assume the labels came with the carpet and not applied at St. Louis.
          Jerry Fuccillo
          Jerry Fuccillo
            Director Region V
            • August 31, 1994
            • 1463
            Re: I see what you mean
            Black, Standard carpet is probably the one month out.
            The span with other colors could be farther out.
            Look forward to meeting you in Flagstaff.
            H. a. N. D.
