C-2 Dash Panel - NCRS Discussion Boards
C-2 Dash Panel
+ More Options
Posts
  • Hector G.
    • November 1, 2004
    • 234
    C-2 Dash Panel
    The JG indicates that the upper dash panel around the speaker grille and the center vertical area above the console is a low gloss paint color. I am in the process of painting this area. Any suggestions on how to prep and paint this area? Any recommendations on a particular paint that would be correct for this area? Thanks in advance for you help. Hector
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: C-2 Dash Panel
    Spend a LOT of time cleaning this area as they typically have ARMOR-ALL or such which doesn't remove easily. You didn't state what color so I can't recommend anything. If you have paint adhesion problems such as "fish-eyes" a product called BULLDOG Adhesion promoter worked well as a base for the paint.
    • Hector G.
      • November 1, 2004
      • 234
      Re: C-2 Dash Panel
      Sorry. It's black.
      • Stephen L.
        • May 31, 1984
        • 3159
        Re: C-2 Dash Panel
        Try the Krylon flat black or ultra flat black. They worked for me.
        • Alan Drake
          Re: C-2 Dash Panel
          If it is a flat black - not such what it should be however.
          Try SEM Bumper Coater, 39103. It has a very very low finish, just above satin.
          Try a search also, I've seen past discussions on this part.
          • William O.
            • April 30, 2001
            • 355
            Re: C-2 Dash Panel
            I have had excellent results with Seymour HI-TECH Lacquer Coating Semi-gloss black.
            Bill
            • George C.
              • November 1, 2001
              • 568
              Re: C-2 Dash Panel
              Hector,
              As others have mentioned there is allot of discussion on this subject in the archives. I used the semi-flat black Krylon spray cans available at discount and auto parts stores, and I think it looks great. This paint is very easy to use, and forgiving. If you don't like the finish sand lightly and shoot another coat. Others have also recomended John Deere blitz black paint.
              George
              #36809
              • Hector G.
                • November 1, 2004
                • 234
                Re: C-2 Dash Panel
                Thank you for all of your responses. Hector
                • Richard S.
                  • November 1, 1994
                  • 809
                  Re: C-2 Dash Panel
                  Krylon semi-flat black worked well on both my 66 and 67....easy to apply and exactly the right sheen....long lasting too....
                  • Hector G.
                    • November 1, 2004
                    • 234
                    Re: C-2 Dash Panel
                    Thanks Rick. I've used the same paint many years ago and had positive results as well.
