I went to change the oil filter in my 63. The long retaining bolt came right out of the cannister when I loostened it. Now I have the assembly out and I want to make sure I get the pieces in the correct order. First should there be a washer on the end of the bolt where it is against the cannister? The order of the parts in the cannister when I removed them from the inside going into the assenbly was; Cone piece, rubber washer, metal washer, spring. It would seem to make more sense if the Rubber washer were against the cannister (to seal it against leaking) then the metal washer the spring the cone and I would think there should be a metal washer on the outside of the cannister under the long bolt. The assembly didn't leak before but I do remember cranking it very tight to prevent leaking.
As always thanks for the assistance.
