C2 '67 door panel removal - NCRS Discussion Boards
  • Tom Merkel
    I need to remove the '67 vert door panels for a couple of reasons.
    Yesterday, it became clear that there is a technique and/or a special tool required to get both window cranks and the lock button off.
    These panels are original and in perfect condition, so I don't want to get too Bubba-like and screw them up.
    Advice and input appreciated.
    Thanks.
    Tom
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C2 '67 door panel removal
    most NAPA-type stores will sell you a tool to remove the horseshoe clip that retains the handles to the splined shafts of the regulators. since your door panels are original and mint, i'd take the tool to a local junkyard and practice on handle removal before going after your car's handles. mike
      In addition to the special tool designed for the job of pushing the horseshoe clip off the crank shaft, some of us prefer to use an L-shaped pick. You simply push the door panel back against the door to gain a modest bit of clearance so you can look with a flashlight behind the handle, see where the clip is and use the L-pick as a probe to grab and pull the C-clip free from the crank shaft...
        I made a U-shaped shim out of the smooth plastic lid for a coffee can to use between the handle removal tool and the surface of the trim panel so you can slide the tool into position without scraping the trim panel surface.
        • Gary B.
          • February 1, 1997
          • 7030
          L-shaped pick
          Tom,
          John's L-shaped pick can easily be made from a large paper clip. I think this is the only safe way to remove the lock knob. I previously tried using the special tool from LIC, but it was never going to work without damaging my door panel.
          Gary
          • Dale S.
            • November 12, 2007
            • 1224
            Re: L-shaped pick
            K-D tool make's one. It works great and no damage. I would use the idea if the coffee can lid if I need to again(door panels used to be not that expensive).
            • Philip C.
              • December 1, 1984
              • 1117
              Re: C2 '67 door panel removal NO TOOLS
              Hi Tom I use a clean rag, I thread it under the crank handle and with a circular motion you snag the clip and it pops right off. (takes a little practice). Then take some blue painters tape and tape off the doors above the panels, use a couple of layers, as you pull up on the panels they rub against the doors. Hope this helps Phil 8063
              • Tom Merkel
                Thanks to all for good tips and info!!
                Thanks, gentlemen. Those tips and info were exactly what I needed.
                Tom
