C2:67 Back to my original clock - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    And here it is:
    This is after removing the quartz movement, and putting back my original (refurbed) movement. I also painted the inner bezel, put in a new lense and outer bezel.
    Forgot to adjust the minute and hour hands to relative positions, but caught that just before I put it back in the car. Works like a charm, and now I'll be working on the adjustment from the owners manual. Thanks guys, for the tip.
    Forgot how easy it is to remove or replace a C2 clock. Just reach in behind the console from the passenger side and remove 2 clips. Got it down to less then a minute, in or out. I feel sorry for you C3 guys.
    Here it is coming out:
    And here's the two clips:
    So, today I made 25 points on ops, and 2 on interior. Now if I get that horn button fixed to blow on four quadrants, and that blinkin' blinkin' headlight warning light bulb changed, I'll be perfect on Operations.
    And still having fun,
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • Rick S.
    • January 1, 2003
    • 1203
    Re: C2:67 Back to my original clock
    Jerry,
    Is there a 25 point deduction for having a quartz movement clock?
    • Bob M.
      • June 30, 2004
      • 20
      Gerard, who did you get to convert back to original type movement? I have one that needs to be done.
      Bob
      • Gerard F.
        • June 30, 2004
        • 3806
        Rick,
        I got a full deduct of 25 on Operations at Flight Judging for a quartz movement.
        The judges noticed the quartz movement sweep in about 10 seconds.
        Jerry Fuccillo
        Jerry Fuccillo
        • Gerard F.
          • June 30, 2004
          • 3806
          Bob,
          I went to a guy on ebay, named skybob1. I just sent him my original movement which I had saved when I did the quartz conversion some years ago. He replaced the points, magnet, cleaned and adjusted the unit. You can also send him the whole clock. Going rate was $35 plus $8 shipping for the movement repair. If you need other parts, it will probably be extra.
          The service was good with a pretty fast turnaround. I found the service by doing an ebay search under "Corvette Clock"
          Jerry Fuccillo
          Jerry Fuccillo
          • Gerard F.
            • June 30, 2004
            • 3806
            Here's a Link
            Jerry Fuccillo
            • Michael W.
              • April 1, 1997
              • 4290
              25 point deduct
              and you wonder why people get so excited over the 88 points for an engine stamping pad.
