62 Rear Shocks - NCRS Discussion Boards
62 Rear Shocks
  • Terry D.
    • May 31, 1987
    • 2691
    62 Rear Shocks
    Ok I'm getting old and senile, but it seems to me there used to be an easy way to get the top nut off or maybe I'm just hoping this is an easy way. Any neat little tricks would be greatly appreciated.
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 62 Rear Shocks
    You can remove the tank cover if you don't like busting your knuckles from underneath.
    • Mike E.
      • February 28, 1975
      • 5138
      Re: 62 Rear Shocks
      Wayne,
      I'm not sure I follow your post. On a 62, what help is removing the gas tank cover to take off the shocks? There are no access holes unless you create them yourself.
      • Terry R.
        • March 1, 2005
        • 359
        Re: 62 Rear Shocks
        Put your 9/16 wrench on the the nut and turn the top shock housing. Will make quick work of it. Terry
        • Wayne P.
          • August 31, 1975
          • 1025
          Re: 62 Rear Shocks
          Been a while. Guess I was thinking of earlier model C1.
          • Terry D.
            • May 31, 1987
            • 2691
            Re: 62 Rear Shocks
            Turn it with what? There ain't a lot of room up there to do that. I can't even get a rachet wrench to work. And there are no access holes from above.
            • Mike E.
              • February 28, 1975
              • 5138
              Re: 62 Rear Shocks
              Put a box end on the nut, then grab the actual top portion of the shock body and turn it. The wrench doesn't move at all, it holds the nut, while the top body, with the integral shaft, turns the shaft inside the nut.
