oops - re-threading and broke through - NCRS Discussion Boards
  • Peter B.
    • July 31, 2000
    • 155
    Guys
    I just re-taped my thermostat intake bolts (had to tap out the old broken ones). Guess what..... Yup, I broke through and the threads are now exposed to the antifreeze.
    Can I permatex the threads and still use this manifold or is it toast? Its all original and not restored so whatever I can do to keep it running would be ideal.
    Ideas?
    p.s. Joe - yup, you guessed it.....once you told me the thread sizes, I could not wait to try it out.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: oops - re-threading and broke through
    Yes your OK! you only need to use thread tap,it's no different then the water pump bolts
    • Peter B.
      • July 31, 2000
      • 155
      Wow. Ok no need for another scotch right now. I was nervous.
      What is thread tap? Some special bolt or sealant?
      • Roy B.
        • February 1, 1975
        • 7044
        Re: oops - re-threading and broke through YES *NM*
        • John O.
          • May 31, 1998
          • 480
          Hi Pete
          It's thread TAPE.....Kinda like whats used on gas pipes in your house. Go to the auto parts store. They have it there. Just run it around the threads a few times then screw in the bolts. Or you can use a tube of Blue Permatex (water type)..Just cover the threads with it and screw in the bolts. Either way will work.
          Good luck .....John
          • Dick W.
            • 10483
            Also Loctite and Permatex have products that are teflon paste pipe sealant. They work very well for those of us that have problems with figuring out which way to wrap the teflon tape.
            Dick Whittington
            • Peter B.
              • July 31, 2000
              • 155
              Thanks. I will try it today!
              Have a great Sunday.
              • Jean C.
                • June 30, 2003
                • 688
                Dick, that would be lefty tightie, righty loosie.
                Cheers,
                Charlie
                • Dick W.
                  • 10483
                  Rat bass ackwards ain't it??
                  Dick Whittington
                  • Brian Monticello
                    My intake water neck holes are through holes as well. I just used some RTV and have not had an issue. One of my carb stud holes is also a through hole. For that I used some teflon paste. No problems.
                    Brian
                    • Peter B.
                      • July 31, 2000
                      • 155
                      Great. Thanks.
