Oil filter canister ass'y, for PF141 - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 384
    Looking for comments on the repro oil filter canisters now being sold by Paragon, others. Are they decent in form/fit/function? 'Flight' judging is not a concern. My existing OEM canister no longer exerts spring pressure on the filter & is getting rather dinged up at the mating surface. Thanks.
  • Ken Edmunds
    Re: Oil filter canister ass'y, for PF141
    Send your original to Ken Hansen at Orindales and let him restore it for you. His work is perfect. 713-783-0815
      • 43236
      jeff-----
      From a "form, fit, and functionality" perspective, I think that you won't be disappointed, at all; I think the reproduction will work perfectly.
      • Brian M.
        • February 1, 1997
        • 1840
        I've been told that the repro cannister is thinner than the originals.
        • John L.
          • 409
          I have one of the canisters from Paragon and it is slightly thinner (the walls) than my original. I saw the refurbed canisters from Orindales at Carlisle last year. They looked real good. Also, canisters appear on ebay from time to time.
          • Brian M.
            • February 1, 1997
            • 1840
            Ken did 3 cannisters for me an they look as NEW. Hansen2@bellsouth.net
            • James W.
              • December 1, 1990
              • 2660
              I have an original spare in great condition ready to install if you are interested in it.
              James West
              • Page C.
                • February 1, 1979
                • 802
                Also when Ken Hansen restores yours, He installs a snap ring on the shaft so that you can disasemble it if needed.
                Page Campbell
                • Jeff S.
                  • July 31, 1984
                  • 384
                  Joe
                  Assuming that the cone & spring assembly are functioning properly, how high above the canister should the filter element sit when it is dropped in? I seem to remember ~3/8", but I'm not sure. Thanks.
                    • 43236
                    jeff-----
                    I have not done one of this type in so long that I don't remember.
                    • David Van Weele
                      I will be putting a few originals on ebay next month. I bought a case back in 1979 and only used one.
                      • Jerry Weidner
                        James,
                        How much do you want for the canister?
                        Jerry
                        • Mark Milner
                          Why not just replace the spring? Or at the worse, just buy another old cannister somewhere. They can be found cheap. Only restorers use them, most change to spin on filters.
                          • Philip C.
                            • December 1, 1984
                            • 1117
                            Re:Long Island sells a kit its simple *NM*
