C2:67 Horn Button Probs--Easy Fix??? - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    My horn button on a 67 will blow when I push on two quadrants only -bottom and left. I got dinged on this in operations judging. Is there a easy fix?
    Getting ready for Flagstaff, put in my papers today.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • Geoff C.
    • May 31, 1979
    • 1613
    Yep Horn Contact; $30-50; 3 screws to remove *NM*
    • Stephen L.
      • May 31, 1984
      • 3158
      Re: C2:67 Horn Button Probs--Easy Fix???
      Jerry, You can fix the horn button switch you have. Just did it myself a few months ago. Remove the horn button (it clips on) and this exposes the switch. Remove the switch (3 screws). The switch is held together with some small plastic buttons. Look closely and you should see that if you push the button centers out this will allow the switch to come apart. Clean the contacts, I bead blasted mine, and then reassemble. It'll work good as new unless the switch has EXTREME corrosion.
