65 Tanker - NCRS Discussion Boards
65 Tanker
  • Neil Anderson
    65 Tanker
    I am in the process of restoring a 65 big tank car and would appreciate any info pretaing to the big tank option. In particular 1 how is the interior area behind the seats finished, carpet, vinyl, paint, or combination, 2 is the fan for the rear vents deleted with the big tank, and 3 was separate wiring run to the tank for the fuel gauge sending unit. rather than using the regular wiring harness?
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: 65 Tanker
    Does this help?
    • Neil Anderson
      Re: 65 Tanker
      It appears from the photo that all surfaces are painted to match the interior color. Is that correct? Thanks, Neil
      • Wayne M.
        • March 1, 1980
        • 6414
        No.2 & No. 3 (yes)
        Neil -- Kevin's '64 photo shows the general detail, but I wish I had an original carpeted example to figure out the dimensions behind the seats and up both edges ('65 wheelhouse carpet asm. chart # 3868794).
        Mine is an early '65 (Nov 6 trim tag -- first day production after the strike) and the UAW boys got lazy the last few days before the Sept-Nov walkout and spliced the 36 gal sender harness into the main rear harness opposite your left hip, rather than carry it forward to the under-dash plug. BTW, the '64 and '65 tankers used the rear convertible wiring harness as there was no blower wiring required.
        If you need any specific pics or questions, I can email per your request.
        • Neil Anderson
          Re: No.2 & No. 3 (yes)
          Thanks for the info. My tank sending unit wiring harness is spliced in at the under dash plug, but rather crudely. Any pics would be appreciated. neilhanderson@msn.com
