Original '66 Caliper Bolts - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I believe the two large bolts that hold the brake caliper halves together had a black phosphate finish. Anyone know what the headmarking was on these bolts?
    • 43221
    Re: Original '66 Caliper Bolts
    Rob-----
    The 1965-E67 caliper bolts, front and rear, were PLACE bolts and were black-phosphate finished. "CP" and "L" were 2 common headmarkings; there may have been others, too.
      • 43221
      Addendum--Photo
      Here is a picture of several typical caliper PLACE bolts, front and rear. These have been cleaned up and are "shorn" of their original finish for now. I have a bunch of other NOS examples, but they're too hard for me to get to right now. So, these will have to do.
      • Geoff C.
        • May 31, 1979
        • 1613
        Is there another location on a Vette
        that uses that distinctive head design with the 6 trapezoids separated by those 6 deep grooves? Instantly recognizable as a caliper bolt, or am I all wet again.
        Geoffrey
          • 43221
          Re: Is there another location on a Vette
          Geoffrey-----
          Some C1s MAY have used PLACE BOLTS for the ring gear bolts. I'm not really sure if they did, or not. It seems to me that they were also used for 1 or 2 other locations on C1 and/or C2 Corvettes, but it does not come to me right now.
          As far as I know, there were no PLACE BOLTS used for any C3 application, whatsoever. Their use as caliper bolts ended about simultaneously with the change from the 1st design to 2nd design calipers in early 1967. They may have continued for a short while on 2nd design units, though. I don't think so, but it's possible.
          • Rob A.
            • December 1, 1991
            • 2126
            Re: Addendum--Photo
            Joe,
            Thanks for the photos. I've seen these before and always assumed they were replacements of some type, rather than original. If I would have known, I'd have kept them when I ran across them.
